98ramss/t
- Dec 17, 2014
- 31
- 0
- 1998
- 5.9 Magnum
Just recently i swapped out the kegger intake manifold with the hughes air gap. I changed the o2 sensor (NTK from dodge dealer), spark plugs, wires, cap and rotor when i did the intake. I also had to get a new coolant temp sensor (napa) because the old one broke. The problem is that the engine will not idle properly, it runs rich and i can smell it from the exhaust. It has a cylinder 2 and 4 misfire and sometimes a p0133 (bank 1/sensor 1 slow response) code pops up. I have checked the wiring to the o2 sensor and i can't find any problems. I ordered msd 8.5mm super conductors and i'll be installing them when they arrive. I'm thinking about buying a new cap and rotor as well. I used standard blue streak cap and rotor with brass contacts but i don't know if its any good. I put in champion copper plugs gapped at 0.040 but i'm thinking i'm going to try ngk plugs. I checked the injectors and they are all at 12.2 ohms. I moved the intake air temp sensor into the air cleaner pipe, could this be causing it to run rich? All the spark plugs except cylinder 5 and 7 were covered in black soot. Any ideas on what else to check? Thanks
