Rpm's
COPGUY
New Jersey
Tonight when I was driving to the store, less than a mile away, I noticed my RPM's dropped down to 800 to 1000 while coasting at 45mph. I never noticed this before as I have only been a Ram owner for a little over a month. The temp is starting to get cool at night, about 39 degrees at the time, don't know if that could factor into it. My past vehicles would usually stay about 1200rpm under the same speed and conditions. No dash lights or messages came on and the vehicle seemed to be running normal. Is this a problem or the beginning of a problem?
bigbadram1500
Springfield, IL
Haven't experienced something like this in the rams I've had. Definitely seems odd though. I would maybe try the key trick and see if that pulls any codes.
garner
Harker Heights, TX
Mine has done that a couple of times while cruising. No issues so far with mine
quietpeen
2021 TRX
Hellcat
hmmm i'm gonna have to see if mine does this on the way to work
scoose
Atlanta
2007 1500 sold, 2011 1500 5.7 sport sold, 2016 6.7 2500 4x4 sold, 2014 2500 5.7
I'm driving the 07 to work today and the 11 this afternoon. I will try to duplicate this with both.
I am also betting on MDS.
txbass06
NE Texas
5.9 Magnum
The MDS ( Mulit-Displacement System) cuts the engine down to 4 cylinders under light load or cruising conditions to improve fuel economy
Sent from my iPhone 4 using Tapatalk
SMITHY
KANSAS CITY
2011 Dodge Ram Quad 4x4
4.7 Magnum
I don't believe my 4.7 has the MDS. Glad of it too. I had an 07 Silverado that had that and I could not stand it. Did not seem to help gas mileage at all and made my exhaust sound like ****.
LB3711
Trumbull, CT
3.6L V6
Mine usually idles at 500 or so rpms
Sent from my tapatalk equipped AT&T iPhone 4.
glass3222
Central PA
your 4.7 does not have mds. Only 5.7s in 2006+ 1500s have it. 2500s do not.
Trupiano
Registered User
6.7L CTD
If you have a hemi, it was almost certainly the MDS. Can't believe your dealer didn't tell you about it. basically helps to save gas. When the truck starts to go int MDS mode, you might be able to hear a slight difference in the exhaust tone. Think there's like a light on the dash or something too. Can't remember, been away from my truck for about 6 months now : (
glass3222
Central PA
When do you get to come home?
scoose
Atlanta
Def MDS
LB3711
Trumbull, CT
3.6L V6
Mds isn't that bad. I don't notice it that much.
joshhhh
