runaway
problem
  • injectors
    Votes: 5 100.0%
  • tps
    Votes: 0 0.0%
  • clearence
    Votes: 0 0.0%
  • loose fuel lines
    Votes: 0 0.0%
  • Total voters
ladale21
cummins HO
Hey everyone new on here, not getting any resoinces to the other forum, here is my problem I have no start condition, no code. With the intake off a **** of ether she will start , but run rough, white and grey smoke, she will run with a miss but maintain a low rpm but if I bump the throttle she will creep and run to Max throttle, I don't let it run long enought to see if it comes down but when I give her another shot after shutting it down she will nor smoke that bad I'm checked my oil and its now a lot higher than normal, so I leaning toward injectors, anyone have a way a figuring out which injectors it is, and would diesel in the oil with it being that high cause that runaway condition
05singlecabHEMI
Lilburn,GA
I dont know a lot about diesels but i know white smoke is an injector problem. And id say go ahead and replace all of them. Wouldnt hurt. Thats about all i know. lol sorry. But ill bump the thread for ya
ladale21
ladale21
cummins HO
Thanks , I just came from the 5.9 360 so I'm new too
LB3711
Trumbull, CT
3.6L V6
Welcome to rf
Sent from my tapatalk equipped AT&T iPhone 4.
ramhunter9
P-Star Jeep Wrangler
Could be injectors ... pull one out and inspect . Make sure the holes are not carboned up ect ..
If you need injectors PM me
Mopar1973Man
New Meadows, Idaho
1996 Dodge 1500 (V8-5.9L) & 2002 Dodge Ram 2500 (5.9L Cummins)
Just replace all 6 injectors... While your at it do a compression test and see how much you wiped out the rings from leaking injectors. What happens on the CR engine is as the injectors wear out they start to leak constantly which ends up spraying fuel on the cylinder walls washing out the rings. As in you case you using ether to fire it up because the injectors are leaking so bad you can't make 4,500 PSI in the rail at startup time.
Now the bad new injectors are in the relm of about $3,000 bucks for a set of 6 stock injectors. (Which in 24V terms I could buy 3 VP44's).
Now if the compression is low you might end up doing a ring job on top of it...
Mopar1973Man's Dodge Cummins Articles - Compression Testing
How a common rail injector works...
Common Rail Injector - YouTube
At 2:26 is where the injector start leaking in the valve seat...
ladale21
ladale21
cummins HO
I pulled them and exterior. All look fine yet one or two I could shake and hear the ball rattle
WV Cummer
West Virginia
5.9 Cummins
How many miles on the truck ?
I would not be spraying starting fluid in it!!
My advice to you since you have them out,is to send them off and have them benched tested.Exgery would be who I would deal with but you will pay and there is a reason for that..Also there is Cummins Performance,Scheids.Maybe Ram Hunter could help out with having them tested as well.
Like someone else said if you need to replace one or two just do them all,if not you will be chasing your tail down the road.
ladale21
ladale21
cummins HO
how many miles on the truck ?
My advice to you since you have them out,is to send them off and have them benched tested.exgery would be who i would deal with but you will pay and there is a reason for that..also there is cummins performance,scheids.maybe ram hunter could help out with having them tested as well.
188.888
Mopar1973Man
New Meadows, Idaho
That doesn't mean anything... If the ball can't seat properly and seal then the injector will continue to bleed fuel out the nozzle. Bench testing is the only way to find out. But like I said if you find one fail injector (which you will) make sure you replace all six injectors because the other injectors will be failing right behind the replacement.
Mopar1973Man
New Meadows, Idaho
ladale21
ladale21
cummins HO
Ronsterritory
