Running board lights and cargo lights
Codeyc
Hillsboro missouri
My truck is a 2016 Express cc, I wired in 8 pod lights under the bed caps to the cargo light wire, also I put running board lights in that are wired to the interior lights. The board lights have a blinker option that i thought was cool. Once everything was done I checked operation. Everything works properly and they look great. Door opens running board lights come one, unlock button hit, the bed lights come on. Blinkers work on the board lights also. HOWEVER when I start the truck the cargo light flick on and shut off instantly, the blinkers on the board lights shut off after 10 second (about the same amount of time the bed lights shut down also) but all my normal blinkers still work and that's what the signal is wired into.. I seen someone else had this issue but I cannot find the solution. The bed lights and blinkers are totally different circuits so I'm not sure why they are freaking out only when the engines running.
