running issue
BoDuke
Camden, TN
5.9 magnum
brand new crate 360 motor wont stay running have to keep pedal to the floor toop stay running any ideas
Merc225hp
NA
truck
gas
As posted fuel sync, time to plug it into a Drb scanner. Is this a performance crate motor or just a rebuild?
BoDuke
BoDuke
Camden, TN
5.9 magnum
sorry i know this post is old but the truck still does it from time to time and its usually around the time it rains... it is just a stock crate motor and also what is a drd scanner
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
A DRB scanner is the Mopar vehicle interface, like the Tech-2 for Chevys.
When you put the new engine in you needed to relearn a couple things into the PCM for it to run correctly. Fuel sync being the biggest, others include APPS relearn, and fuel trim reset. The last two you can do yourself, but the most important one you need to take to the dealer or a specialty shop that deals with enough Chrysler products to have one. It costs about 80-100 for the Fuel sync depending on dealer or specialty shop in my area.
dapepper9
Iowa/Nebraska Border
5.9L V8
If you haven't done fuel sync yet, this will get you close. From here it can be fine tuned with the dealer scanner
BoDuke
BoDuke
Camden, TN
5.9 magnum
if none of these things have been done what will it cause the motor to do?
dudeman2009
Magnum 360
Exactly what it's doing now, not stay running.
BoDuke
BoDuke
Camden, TN
5.9 magnum
it does stay running most of the time its just every so often it will have a spell where it seems like it might be in limp mode
joshhhh
