Rust belt?
Udy2554
Udy2554
Naples, NY
It's fairly predictable what they use here. I don't recall seeing sand on the interstate or county highways. If they do use it, they must use very little. Most of the time after the state and county plow trucks are done the roads appear to be bare pavement. It looks like they use 100% salt. But things change dramatically once you hit the town road. You're in a whole new world then. There's usually a layer of sand on top of packed down snow or ice. They must use some salt but it has to be very little. It's about six miles to my house from where the town road starts. Many times after snow the town plow truck hasn't even been through there yet. More than once I've used 4WD for the trek. Once late Spring hits and no more possibility of snow the town uses a street sweeper to clear the sand from the road in our hamlet. I don't know how far from the hamlet they use the sweet sweeper but I know they don't use it on the miles of roads once you leave the hamlet. I guess that over time the rain clears the sand or at least most of it. In early Spring on a nice day some bikers will jump the gun and come out to enjoy the scenery on the back roads. What they don't realize is that there is still sand on some of these roads or realize what sand can do to traction when rounding a corner. Been more than one bike spill as a result of it.
I’m on a steep hill now! Someone with money complained at some point! They must dump and run with the salt on my road! It’s white until there’s a few good rains in the spring!
Where I lived for 21 years before, it was a heavy sand mix on top of packed snow! Reasonable driving with actual snow tires worked well! All season tires are terrible on snowy roads! It’s rediculous how people who lived here can’t drive on snow!!!
Dodge 1500 4X4
Rochester, NY
Granular salt, or a mix with sand! I have a little bit of every kind of living around me! Dirt roads, multi-million dollar lake homes(look up the Sands Castle), villages, state highways! They all use something a little different!
In upstate NY they use Mag chloride & rock salt, the liquid Mag is for the low temperatures, it will leave a solid white streak on the side of the vehicle, and if they used that cold patch asphalt to fill the potholes don't worry this mixture removes all of this patch work so now the roads are all tore up, this is due to the temp changes this mix gets under the patch and liquifies it.
Gemeni06
Northern Adirondacks
4.7 Liter Flex Fuel V8
Ditto that on snow rated tires. I know the difference as well. The RAM's got all season's. The XTerra's got snow's. When there's even a hint of snow it's the XTerra.
Udy2554
Udy2554
Naples, NY
Kenda Klever RTs for the summer, Kenda Klever RTs studded for the winter!
