Sanity Check on battery\alternator wiring
yer_muther
5.9 Magnum
98 Ram 1500 and previous butchered the battery wiring. Can someone tell me a few things. Where does the heavy wire from the Alternator go? I think it's the PDU post closest to the cab but the wiring diagram has me jammed up. From the positive battery post there should be a wire to the starter and also the PDU lug closest to the battery correct? The negative battery post should have a ground to the fender, the motor, and the chassis correct? Thanks all!
southalum
