Seafoam plus check engine light
bloombloom88
Plano, Texas
I ran some seafoam through my motor, and halfway down the road my check engine light comes on. Now the truck is hesitant taking off from a stop light.
Any ideas?
I'm waiting inline at autozone to pull some codes
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Did you let it sit, then let it run till all of the carbon was done burning off throughout the rpm range?
Sent from my VS920 4G
05singlecabHEMI
Lilburn,GA
i agree with rob let it run for a while. maybe rev it up to 3k rpm for a few seconds.
bloombloom88
bloombloom88
Plano, Texas
Yes, I let it sit with the motor off for 5 mins like it says on the can, like I've always done on any of my vehicles. Then as soon as I started driving it, it ran like ****. There is no more white smoke coming out the exhaust, I ran around for about 30 mins.
It seems like it runs almost like it did before I started, but the check engine light is still on
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
I would reset the pcm to clear the code, then start it up and run it through the rpm's to get it hot enough to burn off watever is left in the system.
bloombloom88
bloombloom88
Plano, Texas
The light is off now, I guess some carbon got caught on one of the o2 sensors.
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Awesome!! You usually undo the battery or pull the pcm fuse. Is the truck still acting up?
bloombloom88
bloombloom88
Plano, Texas
No, it seems to be running fine now. The guy at autozone is a ******* *******. He said it probably messed up a sensor and that I never should have done it with only 53,000 miles.
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Pshhh..... Hahaha I do it every 3rd oil change. You never know how bad some gas can gunk up **** lol.
I'm glad you got it right.
quietpeen
2021 TRX
Hellcat
next time try just starting the truck and revving it like stated before till all the white smoke gone, vs. letting it sit then immediately driving it. Not sure if that will make a difference, but that is what i have read and seen on how to do it
bloombloom88
bloombloom88
Plano, Texas
I'll try that next time, btw the ******* check engine light came back on today. FTW
n2wind2000
Similar problem, had a friend Seafoam it yesterday after changing Valve Cover gaskets. Waited 5 minutes, then a 3000 rpm idle for several moments until smoke cleared. Check engine light is on and it runs rough as hell. Borderline non operable.. I attempted to warm it up on the roadway, when I got to about 30 mph the CE Light started flashing. I can still smell Seafoam as well. I removed and inspected all 8 plugs (5.2l) and all looked great, changed about 20k ago and plug wires as well, Distributor cap about 1k ago. I used my Autel to read codes, P0300, 306 and 308. Im really at a loss guys, any help appreciated. Also worth mentioning, a new Cat about 30k ago. I have 108k on it now. I also get :
CAT NOT READY
EVAP NOT READY
O2s NOT READY
And MISFIRE READY?
Ryan12
Killeen, Texas
I dump it in my oil and gas tank every third oil change and have never had any problems.
tkyle486
wow note to self dont' do seafoam, sounds bad!!!
