Seat belts, dome and power windows help!!
Moparornocar0346
Mount Sterling
5.9 liter
Hello all. I have a 99 Dodge Ram 1500. Not sure what is going on. But my seatbelts r locked and my light is on, my power windows quit working and my dome light also stopped working as well. I checked the iod fuse. It’s good is there anymore fuses related to this parts? Any helps would be greatly appreciated
Moparornocar0346
Moparornocar0346
Mount Sterling
5.9 liter
Ok so something interesting to add. So my middle dome light will come on but is very dim but here is the kicker. I have to take the bulb out now bc whenever the map lights go off after shutting the door. The middle dome will come on
Joe w.
Virginia
318 5.2l
That's weird I don't have a clue what it could be unless it's a short in wiring.
Moparornocar0346
Moparornocar0346
Mount Sterling
5.9 liter
I’m stumped man. I hate to do it but imma bout to take it to the stealer
Joe w.
Virginia
318 5.2l
I know when my seat belts locked on me which was my fault lol. I ended up replacing my seats with some from a junkyard. Cause I wasn't paying $400 for a dealer to fix it. My guess on the seat belts is that you lost full power some how. Can you trace the wires going to and from the seat belts under the seat and up thru the seat cover. Maybe you have a broken wire or a short
Joe w.
Virginia
318 5.2l
Another thing to checkout is the SCTM box it controls the power to your seat belts it's a little black box underneath the middle seat. It may be bad.
Moparornocar0346
Moparornocar0346
Mount Sterling
5.9 liter
I hear that all of that is ran together as well. That there is some splice somewhere in the wiring?
David Driskell
Montgomery Alabama
Question to add, 01 1500 5.2 automatic
same as already described in addition, it stumbles, pops, sounds like spitting back through a carburetor that’s not there. Idles fine, but won’t move 2 mph until it gets through pitching it’s fit. Then it runs like ***** ape. Sometimes I find the LOD fuse blown. Seat belt light and check engine light stay on.
Spike95
Houston
For the original poster, I would say look for a bad ground connection somewhere. Most of the time when multiple electrical systems start acting funny simultaneously, it is a ground issue. Will probably be connected to the firewall somewhere. The dim light is especially telling... All it takes is a very slightly loose connection to cause all kinds of havoc.
David, I don’t know that your engine problems would be related to your interior problems, but still a good idea to check all grounds when multiple things act funny at the same time. You might also check that the IOD fuse terminals are not corroded.
Reactions: Mop
Skatulaki
Green Cove Springs
5.9 liter 360
Let me ask you , did you do any work on it before you started having the problem? I worked on copy machines for 30 years as well as my own cars. The reason I mention this is because many electrical problems "can" be self inflicted if you have done some work and not realized that you pinched a couple wires. While not necessarily shorting them out, they can be partly grounded and cause all manner of screwy problems. Just a thought.
David Driskell
Montgomery Alabama
Not this time, wish I had would have had something to back track on. It’s just starting acting up, replaced gas cap (just to satisfy a code). Now have an intermediate down stream O2 sensor code coming up. Can make a run above 60 mph for 10 miles check engine light will go out until I drop back below 60 mph for 5 miles then light returns.
Have dumped 2 cans of Seafoam in tank and topped off with BP (White gas) high Octane going to give it a try
