Security and remote start?
Royals
KCMO
I'm in the market for a security/ remote start system. Mainly security since I have to park my truck in some not so great areas for work every once in awhile. What are you guys running or have heard good things about?
baum
savage, mn
2015 Laramie
dei, compustar, autopage, audiovox.
i have had them all/installed them at a shop setting. All have their ups/downs they all offer different features.
Since all alarms/remote starts need a bypass module. you can control aftermarket alarms/remote starters from the factory FOB. i would look into doing this, then getting a cell phone module so you can get notifications on your phone or have functions from your phone.
what it really come down to is the features you want. price.
just keep in mind that you can have the cheapest alarm out there with a good install and have no issues or you can have a $1k alarm with a bad install and have lots of issues. do your homework on the shop also.
adrianp89
Tampa Bay, FL
The Compustar system with the T-Harness is a super easy install, and a great alarm.
DannyMK2
Long Island, NY
2015 Power Wagon
directed 5x10. easy enough to install yourself, uses the factory remote, smart start and 2 way compatible if you choose, not all that expensive either.
scotts2012ram
Ms
I did the 5x10 kit with t- harness and two way paging. I love it wish my last truck was as easy. Order mine on ebay was programed and everything
abdely2k
hemi
Hello first time in this forum i am really interested on buying the 5x10 could you tell me where you buy this? how difficult is to install it yourself?? thanks
baum
savage, mn
2015 Laramie
depends. get the t-harness and its almost plug and play.
its getting unit flashed with the software for your truck that can be tough. some ebay sellers will, but not all.
fastbike02
GB
i just bought a 5x10 with t harness and was wondering if yall could give me some insite on the parking light wires, do i need to hook them up or is the 1 wire going to the white wire on the back of the switch enough?
baum
savage, mn
2015 Laramie
do you have the manual for it? it tells you exactly where to get it at.
otherwise google 5x10 and go to the directed site and you can put in your truck and it will give you the instructions.
DannyMK2
Long Island, NY
2015 Power Wagon
parking light wire is optional but its nice to have, imo. i believe i grabbed it from the BCM since thats what the directions outlined, but you could grab it from behind the switch.
fastbike02
GB
I couldn't get it to work so I'm going to take it to a shop tomorrow and have them install it
DannyMK2
Long Island, NY
2015 Power Wagon
how come? the alarm is pretty much plug and play. it should somewhat function without having to splice any wires.
fastbike02
GB
it seems i had it programmed wrong, but i got it installed today it cost me 150 including programming a spare key I had so it wasn't to bad of a deal.
bcbouy
pitt meadows/100 mile house
2021 power wagon
hemi
in the last week i had a remote start,front and rear cameras,switch for my rear floods,switch for the cameras and a sub done by a shop.all in for just over 1500.well worth it or i'd have an extra hole in my head.i've always hated doing electrical on vehicles.next up for me is onboard air.i'll mount it but there's no way im wiring it.
adrianp89
Tampa Bay, FL
Glad you got it working! Sometimes the $$$ is worth the time and frustration.
dexter
Banned
I looked into aftermarket alarms after I got my 2500. From what I can tell they do the same as what the installed system does.
Am I wrong?
DannyMK2
Long Island, NY
2015 Power Wagon
Am I wrong?
to an extent, yes. but an aftermarket alarm gives you the ability to add extra functions you might not have, customize setting, added security, shock sensor, etc. biggest thing for me is i forget to lock my truck sometimes. factory alarm is useless in this situation.
baum
savage, mn
2015 Laramie
To go off of this also, not all factory units are actually alarms also. some are just keyless entries but sold as "alarms".
Also for the remote start part range of an aftermarket unit can be 10X that of a factory (remotes only not smart phone apps).
dexter
Banned
Thanks,
Do you know of a system that disables the engine? Or is that really needed. I have the RF(?) type key that you insert and turn. I don't know if those are easy for a thief to override and get the truck started.
I used to have a manual kill switch and hood lock on my Dakota and I loved it. It was old school but a thief probably couldn't figure it out.
This is what the manual says the installed alarm does:
"The Vehicle Security Alarm monitors the vehicle doors
and ignition for unauthorized operation. When the Vehicle
Security Alarm is activated, interior switches for
door locks are disabled. The system provides both audible
and visible signals for the first three minutes the
horn will sound and the headlights will turn on, the park
lamps and/or turn signals will flash and Vehicle Security
Light will flash repeatedly. For an additional 15 minutes
only, the headlights will turn on, the park lamps and/or
turn signals, and Vehicle Security Light will flash."
geneseedennis
