service 4wd that doesn’t turn off
4xdad
Edmonton Alberta
2015 powerwagon
the transfer case fell out of my truck (literally). after much swearing and yelling i finally got it fixed. but now there is warning to service the 4wd system. i put fresh gear oil in it and tried to reset it but to no avail. any suggestions
Who installed the transmission,as that had to be an installer error when the transmission was replaced.
4xdad
4xdad
Edmonton Alberta
2015 powerwagon
you are correct sir. the transfer case fell out of my truck (literally). i worked on it until it got cold. now that spring is here in alberta it’s back in. it seems to work fine but i still have a check transfer case code that i can’t clear. i have tried to reset it by disconnecting the battery.
4xdad
4xdad
Edmonton Alberta
2015 powerwagon
my blue driver doesn’t seem to clear it
GeauxinUp
Navy Badge
Louisiana
2026 Limited
3.0L TT H.O.
What's the code?
4xdad
4xdad
Edmonton Alberta
2015 powerwagon
i’m going to fight with again today. i have a 4x4 shift motor coming. its the one on the axle. a power wagon has a lever on the floor with a handle
4xdad
4xdad
Edmonton Alberta
2015 powerwagon
when i shift into 4x4 it seems to work but i am going to have to find some mud to make sure. it definitely goes into low range but i dont know if the axle is engaged.
DILLIGAF
Canadian Forces
Canada
It could only be a couple things. Bad wiring, Actuator going bad, and faulty wheel speed sensors.
4xdad
4xdad
Edmonton Alberta
2015 powerwagon
i have ordered a new actuator. so we shall see i hate just throwing parts at a problem. but the part in question isn’t that expensive so i will try it. it’s supposed to be here tomorrow
RamCares
n/a
n/a
We would like to see if any TSB's or STAR cases exist. At any time, DM us, and we can check.
Chris,
Ram Cares
Glowz
