Several Engine Codes
Brad Biggs
Ok
I have a 2008 Ram 1500 5.7 Hemi. Recently it started throwing codes idling like crap not going over 10 mph, and not going above 2000 rpm. I have replaced the MAP sensor, Crank and cam sensors, oil pressure sensor and throttle body. It still does the same thing and these are the codes its still throwing.
P0122 - Throttle/Pedal Position sensor Switch A Circuit Low
P0335 - Crankshaft Position Sensor A Circuit
P0339 - Crankshaft Position Sensor A Circuit Intermittent
P0522 - Engine Oil Pressure Sensor/Switch Low
jws123
nj
Have you tested your battery and alternator? oil pressure switch common failure on older trucks same for crank sensors will make it run like **** .
B
Brad Biggs
Ok
I havent tested the battery or alternator. I will do those this weekend. I have replaced both the oil pressure switch and crank sensors and it didnt make a difference.
