Shaking after 65MPH
TonyC
Danville NH
So here is my issue.
I bought a used 2014 Ram Laramie 4 x 4. Ever since I've had the truck it shakes when I go over 65MPH.
I have had new tires put on it ,balanced, new front struts,etc. When I am cruising above 65 MPH and put the cruise control on the shaking seems to calm down. I have ruled out tires (3 sets no change) It has been balanced 4 times. I'm wondering if it has anything to do with drive shaft . Any help would be appreciated
ptuttle78
IMG_1164.jpgwas having the same issue
RamInfo
Utah
5.7L HEMI
Did you have the runout on the rims checked when you had tires mounted? I had the same issue and had to have two rims straightened and a road force balance to get it tamed. If I ever swap rims on my truck it won’t be for looks, sizing, or load rating—it will be because the OEM Laramie wheels get bent too easily.
DG
T
TonyC
Danville NH
i HAVE NOT HAD THE RUNOUT CHECKED ON THE RIMS. I HAVE HAD IT ROAD FORCE BALANCED 3 TIMES.
Thanks FOR THE INPUT I'll PUT THAT ON MY LIST WHEN I TAKE IT IN NEXT TIME.
VB712
Maxi_built
Va Beach
Very common on crew cab 4wds. Mine has done it since I bought it 3 years ago.
T
TonyC
Danville NH
Thanks for the input makes me feel a little better
The part that has me baffled is the fact that it seems to get better when using cruise control
Reticle918
