Shaking HID
61N150W
Anchorage, AK
Hey all,
I have the Diode Dynamics 35w HID kit and overall been really happy with it. However, my passenger side "shakes" and "bounces" a lot. Really evident on roads with a lot of ice build-up.
I feel like I've checked everything. I pulled the housing, made sure the bulb was seated (sat?) properly, tightened everything down, even the latch on the backside. Alas, the shake resides.
Is there a chance the element in the bulb itself it to blame?
I can stand outside the truck and bang on the housing, but it doesn't replicate the issue.
IRSmart
I drink and I know things
Westminster, MD
2018 Power Wagon
6.4L Hemi
Could it be the headlight itself? Is the locking tab fully engaged?
TatertotScott
The man, the myth, the legend, the one and only!
La Center/Amboy, WA
I would check the bottom bolt on the housing, as well as the top bolt and locking tab. More likely the housing itself is bouncing than the bulb.
Tapatalked from my expensive "smart" phone.
61N150W
61N150W
Anchorage, AK
Yeah, I've double checked everything. I've had these housings in and out at least a dozen times before, so pretty used to the drill.
Think my next step is pulling the bulb and see if there are any issues present.
pgr1990
Are you sure it isn’t the projector shaking? Try swapping bulbs to the opposite sides
61N150W
61N150W
Anchorage, AK
I'm not sure honestly. I suppose that could also be the case. You are right, I can swap the bulbs around and drive it around the block; see if the issue transfers.
I'll try to get to it this weekend and report back.
adurm
FL
2015 RCSB
If you can grab the back of the bulb and wiggle it, try adding a second rubber ring from the oem bulb to the hid. Should make a super tight fit.
