Should "I" do this mod for my exhaust
sullivan
Houston, Texas
Right now my exhaust is dumped right after the cab but before the axle, and pointed down. It is a magnaflow exhaust and was pre-existing to my purchase of the truck.
Well, I was thinking of how cool it would be, if it turned 90 degrees, and a tip stuck out the side of the bed before the axle.
I feel I could probably do this via clamps, but would anyone recommend someone new to this to do this? Or should I just find someone to weld it on.
Most of the exhaust is already welded, so i don't see clamping the tip bad...
any input
RubberFrog
I don't see any reason you couldn't do it the way you're planning. Sure you could pay someone else to weld it, but there is a lot of satisfaction in doing it yourself.
adamwilkes14
I DIY'd my whole exhaust on my S10, using clamps...had no probs what so ever!!!
sullivan
sullivan
Houston, Texas
Thanks, is there a specific size of exhaust tubing I probably have or are you guys probably unable to answer this? It's a 5.7 hemi with a magnaflow exhaust. Is it a 3" diamater pipe? I guess I gota cut it and maybe find out myself.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Yep, modding is all about making it your own.
bigtigga84
dela....where?
that's how mine was run. had a dual out and two pipes sticking out before the tire. getting duals 45'd out the back tomorrow :naughty:
pavester
texas
how mine used to be ran
pavester
texas
here you can see where it exited, in front of passenger rear wheel
johnnysart
Albuquerque
5.9 Magnum
I used to have it that way also. heres some old pic's-
reefguy89
laurel de
what did you end up going with? i just ordered my cherrybomb extreme and mag Y. Are you getting it done at luckys garage? if so let me know how they worked out.
bigtigga84
dela....where?
Same setup your goin with lol. If your not busy come down man.
sullivan
sullivan
Houston, Texas
Hey well i want some input first before I do this, because of the place the mufflers welded, I don't know if I can do what i want. I will put up a photo and see what you guys think I should do.
I am going with a Magnaflow tip from autozone. They are measured by inlet, so do i get a 3" inlet? And then what size clamp? I assume the clamp would clamp both 3" pieces together. However, I need a 90 degree turn.
I will get a photo up and see what you guys think I should do.
EDIT:
Are these the clamps I should used to clamp a 90 degree turn to the muffler, and this tip to the 90 degree turn.
http://www.autozone.com/autozone/ac...heavy-duty-exhaust-clamp?itemIdentifier=59033
I hopefully don't need an extension after the 90 degree turn to make the tip long enough out the side. But maybe Ill just buy a longer tip. Like 1' SS tip! Haha Beast
sullivan
sullivan
Houston, Texas
Can any one pop in and tell me about the clamps? I'd like to do this before I run sea foam through my truck.
Redtruck-VA
Virginia
Tyler, that is a standard exhaust clamp that is use on a exhaust system that is assembled using slip joints. You want to attach a 90 degree 3" pipe pointed out the side. The clamp will work for that. Good luck...
sullivan
sullivan
Houston, Texas
Thanks, is there any type of grease/sealant I should use in my connections?
Redtruck-VA
Virginia
No, slip the pieces together and tighten the clamp. Point the threads in a direction that they won't snag debris.
sullivan
sullivan
Houston, Texas
Ok I gotcha, I am going to stop by autozone and hopefully find all the parts I need to do this mod.
Heres how my pipe is now, I'll have to do an immediate 90 degree turn out the side. I'm not sure if it would fit:
Redtruck-VA
Virginia
IDK, looks to me that the rear of the muffler is too far aft to get a clean 90 degree exit out the side. Maybe have a shop run the pipe over the axle and out the side behind the wheel.
