Should I stay away from Hemi because if breaking manifold bolts?
Tach_tech
5.7L HEMI
Honestly it depends. Sometimes we see lifter failure on vehicles with less than 50,000km. The majority of chewed up cams we see though all have other 100,000km.
The 3.6 is still a great engine though. It had some teething issues with cylinder heads and cam phasers when it first came out, but long term reliability still seems pretty good. Makes great power, and has good economy.
Personally for me though, in a truck, I’d want the hemi.
H
Haas
Wisconsin
I can understand that.
huntergreen
Marine Corps Navy Badge
In case you are unaware, tach tech is a Chrysler tech, great to have on the forum. I would listen to him over me. That being said I know quite a few folk with over 100000 miles in wranglers. No issues.
Tach_tech
5.7L HEMI
With as many 3.6 engines that are out there, the actually failure rate for the issues I mentioned is going to be extremely low. The most common issue was the cylinder heads which they actually extended the warranty on them to 10 years/250,000km for the affected years.
huntergreen
With as many 3.6 engines that are out there, the actually failure rate for the issues I mentioned is going to be extremely low. The most common issue was the cylinder heads which they actually extended the warranty on them to 10 years/250,000km for the effected years.
Thanks tach !
H
Haas
Wisconsin
Thanks for letting me know. But yes, he did mention that he's a Chrysler tech.
H
Haas
Wisconsin
I looked this up after it got mentioned here. It appears this was an issue back in 2011-2013 ish? Sometime around there, but it is now a resolved issue? Something with the cylinder heads on one side?
indept
South Jersey
I know guys with a lot more miles in Levi's, ... Just sayin' :D
ptuttle78
LOL.... maybe we should hit RAM/FCA up for exhaust bolt replacements with every oil change???
I’m wondering if they fixed this with the newer trucks. Maybe they should have made it a option when buying the truck [emoji16]
Tach_tech
5.7L HEMI
This issue is supposed to be resolved on the newer 3.6 engines. It was an issue with valve sealing. Carbon would build up on the valve seat and it would create a misfire.
parkerbows
I believe there is more to this story.
there is not. i see the guy everyday driving a jeep liberty that the dealer is letting him use. only problem is he uses his truckfor construction type work.
Sent from my SM-G950U using Tapatalk
Kylehobie16
Greeley, Colorado
Cummins 6.7
Bicycles don't have any of these issues. It's a little tough to tow a boat on a bike but if you've ever seen what they do in China on a bike, you'd see it's entirely possible.:p
Honestly, Jim had it right on. Some vehicles will go 200K with nothing but oil changes, then the same make and model won't go 20K without blowing a head gasket. The later is rare and like all things that make good news, most don't affect you and I or anyone we know yet it still makes the news.
slacadjuster
5.7L
I don't care one way or the other, but I think we all know what he meant. We're talking trucks here. "Car" can sometimes be used as a generic term for automobile.
Exactly. We're talking TRUCKS here. this is a TRUCK forum. Cars are VERY different. What's next, referring to a bicycle as a motor bike?
Shiva
Fairport
not sure if you have seen all the issues with the hemi and lifters destroying cams but its happening. my fiends ram is waiting on an engine. its been in the shop since January. ship date on engine from ram is august
Just wondering what year your friends engine is. 7 months to replace an engine they build hundreds of every day sounds like more to the story.
Pocho808
