Single to Duel
jhedg
Hello all first of what I would imagine will be many more posts. Just picked up a 2020 1500 Classic Tradesman Crew Cab 5.7 bed, 5.7 engine. Is it possible to change my single exhaust to duel without having to replace bumper, or replace anything, I am looking for a aggressive, not super aggressive, but beefier then stock. Looking for the simplest route to go. Thanks
BOWERSFJ
Uniontown OH
I’d buy the muffler you want, and then find a muffler shop in your area that will custom fab an exhaust for you ... Not gonna find one out there on a shelf ... Everything out there is made to go through the cutout rear bumper
stimpy433
IOWA
If you get the OEM dual exhaust, you can swap it out with your single exhaust and run the tips just below the bumper without any problems. That's what I did on my truck until I found a good used dual exhaust cutout bumper local. Once you have the factory dual exhaust then you can swap out to whatever muffler you want without any problems.
This is the only extra part I needed to install the dual exhaust, Isolator 52103717AB. This is the one for a single attachment on the drivers side. On my truck the hanger was already there for it.
