Single valve y-pipe cutout VS two valve Y pipe cut out.
dirtyUPSman
Palatine, IL
So I decided to put a cutout on my exhaust. While researching for a product I came across two styles. The traditional one valve cut out, where when the valve opens for the dump, some exhaust still goes to the muffler and tailpipe, and a newer two valve cut out, where when the dump valve opens simultaneously the valve to the muffler and tailpipe close.
I'm looking for pros and cons opinions to the two valve y-pipe cut out or anyone that has experience with the two valve.
I have included a picture but please keep in mind that the picture doesn't explain it that well.
Thank,
Jim
Nick@GotExhaust
Supporting Vendor
SC
Neither will make much of a difference in power. This mod will be mainly for sound. The manifolds and oem y pipe is where the real restriction is in the exhaust.
if interested QTP makes a fully bolt in solution that we can offer you. Message me if you would like a quote on it.
dirtyUPSman
dirtyUPSman
Palatine, IL
Yeah fully aware that there is no power gain. I got a new cam, tune and torque converter for that. Now I want a bit more rumble at the light. I was just looking to see if anyone has experience with the two value cut out. My one thought was it might sound a bit more louder if the pipe to the muffler was cut off while the dump was open. Yes, I was also looking for a aftermarket y-pipe to replace that restrictive OEM on the truck now. My one thought on that was will my tune be affected or affect the performance. Since it will have a different O2 reading? Not really looking to have it retuned but if it's necessary.
You definitely need a set of long tubes if you're cammed with a convertor,you're leaving a pile of horsepower on the table with the peanut port stock manifolds
dirtyUPSman
dirtyUPSman
Palatine, IL
It wasn't an easy decision to make but I went with shorty headers keeping the original cats and went with an aftermarket split exhaust. Yes I know there is little gain w shorties and I wld be better off w long tubes but like I said a decision needed to be made.
I am interested in getting rid of the original y pipe for the flow and also putting on a cut-out for the sound.
joesstripclub
Kansas City, MO
2021 2500 PW
I think the double valves are more for an active exhaust situation, where you could plumb around a muffler with a straight pipe and get some combinations between full muffler and full bypass.
