Skeptical
BrianMay
2007 Ram 1500 4x4 Laramie
new member, just seeing if I could get an answer. My truck is in the shop today getting the leveling kit up front and 275/65/20 tires.
I was told I had to go with that size due to keeping the factory rims because with a 35, they would rub.
so my question is, is my truck going to look decent? may be a dumb question, just a little nervous
Harley Harrold
USAF Ret. 36+ years service
Navy Badge Air Force Firefighter
Mississippi
5.7L HEMI
:welcome::party36: Because my truck is a two wheel drive, I like the raked look. Your truck should look good.
Bennutts
Cummins 6.7
I have 35x12.50x20 on mine and had to get a 0.5" wheel spacer. a 275/65/20 is basically a 35" tire but only 11.5" wide. You should be just fine.
NWRQC
it'll look good. It measures out to a 34.1 x 10.8 tire, so about an inch taller than the stock size.
trx680
2006 2500HD Mega Cab 4x4
got any pictures?
exactly what tires and wheels did you go with?
quietpeen
2021 TRX
Hellcat
It will look good. With a level you can fit a 35" tire s, the problem is the width of the tire. 285 is about the widest you can go on a stock wheel. Not all trucks are created equal so I'm sure some trucks have fit wider but the majority of them will not
