Sliding window latch
Scotto58
Sodus, NY
360 V8
The latch on the sliding rear window on my 2000 RAm1500 was broken when I bought the truck. I ordered and received a new 1 from Rock Auto. The plastic on the latch part where it's supposed to bend seems very stiff. I've watched 2 videos from 2 different companies and the latches they had appeared more flexible. Mine feels like,if I can even get it to bend enough to latch, it's going to break. the piece of the old 1 seems more flexible.
Anyone else have this issue? I was thinking if I lay it in the sun for a bit or heat it with a heat gun or hair dryer it might make it bend easier. Any other ideas?
Thanks,
Scott
Daw14
South Florida
Maybe you can file some of the mating surfaces to create some more give . With 25 yr old trucks sometimes a little tweaking of parts , to make them function properly is necessary.
S
Scotto58
Sodus, NY
360 V8
Thanks for the suggestion. FYI the one I got is made by Dorman. The videos I watched were from A1 Auto. The 1 they sell is a different brand and I found a third brand. Don't know if they are easier to bend, but mine cost $5.22. The ones from A1 are $24.95.
