Slight engine noise. 04 5.7 hemi.
Discussion in 'Engine & Performance' started by Chrismb5.7, Apr 14, 2019.
Sponsored By: Moe's Performance
  1. Chrismb5.7
    Chrismb5.7 Junior Member
    19
    8
    Apr 14, 2019
    Dandridge, TN.
    Ram Year:
    Engine:
    1500 reg. Cab 2wd if it helps any... But my motor (I assume) is making a slight chat noise. It doesn't happen at cold start... About halfway to operating temp the chatter starts, when the motor is at operating temp the noise quiets down a bit. It follows the sound of the exhaust. I've replaced all manifold bolts. On the passenger side 3 bolts were sheared off at manifold. 0 on the driver side but I replaced them anyway. That's been about 5 months ago (only owned it for 6 months now). The noise hasn't gotten any worse and the truck runs pretty good. Perfect oil pressure, perfect operating temp. About 2 months ago I put a set of shorties on it because I figured it was a warped manifold so I bit the bullet. I can't say for sure that it wasn't the problem because the headers required some fabbing to bolt to the stock Y, and I did it all myself so there may be a leak somewhere else now. Haven't really had time since I got everything back on it to check the welds and joints for leaks. I'm convinced it's not a rodrod bear or anything because my oil pressure would drop right? It would be much louder than a chatter wouldn't it? Also I can only hear it at idle and the sound increases in speed with the rpm until about 1300-1500. I've heard of a warped or cracked flexplate but that would be consistent through every rpm right? I can't tell exactly where the noise is originating but you cannot hear it at all from the front end of the truck or from the top end of the motor.
  2. Chrismb5.7
    19
    8
    Apr 14, 2019
    Dandridge, TN.
    Ram Year:
    Engine:
    I know about the mysterious "hemi tick" but there is no definite ticking noise to attach to the term "hemi tick". Obvious piston slaps, rod knocks, and lifter ticks have all been labeled as "the hemi tick". Also I can't seem to find a video or hear any hemi I get close to making the same noise. I think I have a video if the noise at it's loudest needs to be heard.
  3. Chrismb5.7
    19
    8
    Apr 14, 2019
    Dandridge, TN.
    Ram Year:
    Engine:
    Pretty sure this is before the shorties we're installed. Noise sounds the same though. Never gotten worse .
  4. tidefan1967
    tidefan1967 Senior Member
    51
    1,096
    1,395
    Feb 3, 2018
    Summerville, South Carolina
    Ram Year:
    Engine:
    Your noise is definitely coming from the passenger side down low. I hear a little bit of drivetrain noise which is always amplified with headers. Maybe try a different brand of header gasket/is the connection to the downpipe on that side a good one?
    Just out of curiosity what brand/weight oil are you running? A switch to 5W30 would most likely quiet the other noises down quite a bit.
    Chrismb5.7 likes this.
  5. Chrismb5.7
    19
    8
    Apr 14, 2019
    Dandridge, TN.
    Ram Year:
    Engine:
    Valvoline Full Synthetic 5w-30 with a Mopar filter.
  6. Karlsweg
    Karlsweg Senior Member
    727
    816
    Nov 10, 2017
    SW Florida
    Ram Year:
    Engine:
    Sounds like exhaust but I’m almost deaf lol.
    tidefan1967 and Chrismb5.7 like this.
  7. Chrismb5.7
    19
    8
    Apr 14, 2019
    Dandridge, TN.
    Ram Year:
    Engine:
    Honestly, I feel like there is still a leak somewhere. Maybe the weld bead on the passenger downpipe has a leak in it like Tidefan1967 suggested. Haven't had time to check it out lately but as soon as I get home today I'm gonna spray the pipes down with some soapy water, start it up and see what I get. I do wanna know if anyone else has had this noise and if/how they solved it though.
    tidefan1967 likes this.
  8. Marley
    Marley Member
    57
    81
    41
    Feb 20, 2019
    VA
    Ram Year:
    Engine:
    Stick a rag over exhaust pipe while idling to locate an exhaust leak.
  9. OhioGuy36
    OhioGuy36 Junior Member
    45
    14
    Apr 14, 2019
    US
    Ram Year:
    Engine:
    Hemi tick is manifold broken stud.
    Sent from my SM-G975U using Tapatalk
  10. Old Fart
    Old Fart Senior Member
    58
    134
    124
    Sep 17, 2017
    Timmins, Ontario
    Ram Year:
    2005 Power Wagon
    Engine:
    ^^^Isn't hemi tick camshaft/lifter related?
Share This Page
