Small leak problem
Bronk
Alberta
So for the past month or so my engine light comes on about 2 days after I fuel up. I've just been using a code reader and it says there's a small leak so I just clear it and move on with my day. In the summer I wasn't too concerned, but with winter coming up I would like to use my command start and not have it disabled. I'm tightening the fuel cap enough, I've taken it to the dealership and they did a smoke test and found no leaks, and I've replaced the gas cap. Just wondering if anyone has had the same problem or can think of anything that might fix it. It's a 2014 Ram 1500 sport
cptwing
The Soviet State of Connecticut
2014 3500 ST DRW REG CAB
6.4l Hemi
You have a check engine light for a fuel leak on a near new truck? You bring it to the dealer and they tell you there is nothing wrong? Really????
I say its past time to make a complaint with Fiat!, not that it will definitely solve the issue, but its the next step an keep going until you get them to fix it.
Typical inept unqualified Fiat service clowns, they get their mechanic certification certificates from cracker jacks boxes!
mikep345
