RobS
- Apr 6, 2011
- 26
- 7
- Location
- Mountain View CA
- 1997
- Magnum 5.9
ok, check engine came on after i thought i fixed a problem, so, i replaced the purge solenoid on the back of the intake, when i pulled the lines off, the top line had a truck load of charcoal in it...so i pulled it all the way off from behind the brake booster, dumped it all out, replaced the line, put it all back together, reset the light, truck fired up perfect, seems to be running better...anyway, the point, is that line supposed to have all that charcoal in it, and if not, any fixes? thanks, Rob
