SOLD: Hypertech Speedometer Calibrator 752501
Status
Not open for further replies.
snoty
Orange County, California
For Sale $80
Hypertech Speedometer Calibrator Part # 752501
I used this to correct my speedometer with larger tires. Recently went the AlfaOBD route and no longer need this. I did return my truck to stock with the Hypertech so it can be used on a different vehicle. I also updated it to the latest software through Hypertech’s app. It works great and is easy to use.
2003+ Chrystler/Dodge/Ram Gas and 2005+ Jeep. Please verify compatibility of your vehicle with Hypertech. I’m not sure if it works on 2018+
The Hypertech Speedometer Calibrator can correct your speedometer and odometer for non-stock tires and/or gear ratios. The simple on-screen menu quickly guides you through the process, and in a matter of minutes the vehicle's computer is reprogrammed for accurate readings.
Emissions Certifications: CARB E.O. D-260-22
Speedometer\Odometer Correction
o Speedometer\Odometer Correction For Gears 2.82, 3.07, 3.21, 3.42, 3.55, 3.73, 3.92, 4.10, 4.56, 4.88, 5.13 & 5.38
o Speedometer\Odometer Correction For Tire Sizes 22.5 - 44 inches 1/4 inch increments
Return Back To Factory Settings
o Return Back To Stock
Diagnostic Trouble Codes (DTCs)
o DTCs Read and Clear
Internet Updateable
o Internet Updateable
Status
joshhhh
