Sold Retrofit 4th Gen Headlights. Sold
Status
Not open for further replies.
WilliamS
Tampa FL
Built for plug and play on Quads, will work with Duals with a relay for the high beam switch (duals will need quad headlight stock harness).
Just finished these in time to trade in the truck. They are built off repo duals so I could fit the giant D2S bixenon projector and rgb halo. They have Morimoto 5k bulbs, power house 35 watt to 55 watt on high beam ballasts. All the hardware needed to run the halos through your phone on bluetooth with a free app. As well comes with not pictures 2 waterproof strips that connect to the halos that can be used as accent lighting that also chase and color change. I used morimoto sealer on both, then went around that with clear silicone to seal them the very best I could. One headlight has a small rub mark that will buff out.
Comes the canbus resistors, wiring for high beam for ballast connection and hi/low shutter for projector as well. The caps are setup for all the wiring.
Only things needed will be the harness from your stock quad headlights. Once you remove the stock headlights the harness between the truck and the headlight will be used to power this setup. Is 100% plug and play.
Im thinking $500 shipped to the US, I wont ship out of the continental US, dont ask, isnt happening.
62df353eebbfae0fc51935535ae19f4f.jpg150079e4d0220d28d0ef2d0f6bb2bbf8.jpgac32a425d8251a8008c7c6ed658d5b8c.jpg5c8555f90a8fdf87901ccf165ae2be73.jpgf2e04c6eeaf3a0d1eab58b4a08bbd7a0.jpg153bb2ea1f76fd8ad2988261109ec7d8.jpg754ca018ea4151351c3f8102af6dbb4e.jpg
W
WilliamS
Tampa FL
That a great price! GLWS. Don’t mean to butt in but I have a set of brand new projectors like the ones pictured in case anyone is interested in attempting a similar setup.
Should I raise the price? Did I mess up? Hmmmmmm
Hudson
GA
Can those halos be turned off completely
W
WilliamS
Tampa FL
Yes they can be turned off, and made any solid color as well 160 different chasing patterns. The halos are on a separate controller and power supply so a switch can be easily used to control when they are on.
W
WilliamS
Tampa FL
Added more pictures
A shot of the cut off when the sun is still up, so you get an idea of how bright they are as well.
2 days of hard rain, and a pressure wash style car wash and no fogging!
W
WilliamS
Tampa FL
If only they were black :(
I’d say I’ll take them apart and spray them, but I’d be lying. I was able to get a perfect line and clean seal first try. No way I’m gonna roll the dice again
cdchris12
Interested in $450 via PayPal shipped to 58201?
Skyjockey
Lowell MA
2019 Warlock 4x4
3.6L
Was going to send message but I'm too old to figure that out ! Didn't want to hijack your thread.
I was looking to get a new set of lights for my 2012 but black. You mentioned needing a harness adaptor? I have the cheap duals and all the lights I'm finding are quad. What exactly is needed to make a quad setup work in a dual truck??
W
WilliamS
Tampa FL
Is your truck lifted or leveled. Without either I dont think they would throw far enough. My truck is nose high so I can get them where i want them near maxed out, but if your stock or nose down I dont think you would get the distance you want. Just being honest.
cdchris12
My truck is stock ride height, actually. I don't think I'll be lifting it any time soon, to be honest; it's got more than enough ride height for me. Thanks for the words of warning, and glws!
W
WilliamS
Tampa FL
Just wanted to be upfront
3.0 eco
Are these still available?
Sent from my SM-N950U using Tapatalk
Status
Arturo Rojas
