Soon to be towing, 2010 4.10s , 6.7
Long Islander
Summins 6.7
I come from a 1500 Hemi 3.55 with Hellwig's sway bars, firestone air bags and Monroe Sensor-tracs in the rear with a Prodigy P2 brake controller
Now I will soon have a 2010 4.10 6.7 with a built in brake controller.
1. Do I need to get any sway bars in the rear?
2. Air bags? yes? No?
Im towing 9,000 pounds, 31ft camper.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
I think you were part of discussion in another thread but I don't think you will need anything to tow that comfortably with 2500. 6.7L with 4.10's has to be a beast! Are you just messing with me calling it a Summins in your infor section to the left?
Stangshcky12
Oshkosh, WI
5.9 Cummins
For 9,000 you dont want 4.10s
My buddies 5.9 with 4.10s and 35s holds 2600 rpm at 75mph if I remember right
Statcher1
Kentucky
You will be fine with that setup. It should be able to pull a house down. But you will rev alittle higher on the highway.
whatroads
2011 QC 4x4
Hemi 5.7 w/ 3.92
From your post it appears you have a travel trailer. If so, I would still suggest a quality WDH in the 10-12K lb range. It will help compensate for the length of the trailer, (sway), as well as the tongue weight. Yes, even with your heavy duty truck
L
Long Islander
Summins 6.7
Update, this vehicle tows like a dream. I love the brake controller and the turbo brake!
shanmccarthy
