Specs for the Camera? (Dual Camera Trailer Kit - Mopar part # 82216068AD)
de1212
Alabama
Greetings all. Three linked questions for you...
I have a 2021 RAM 2500 Laramie with the "Mopar Trailer Camera Wrong/No Camera (XFQ)" package. I'm close to buying a back-up camera to help in towing a 5th Wheel. I know the appropriate Mopar part for the camera and wiring harnesses to run it back is 82216068AD. However, I'd like to know more about what I'm buying before dropping about $650!
Question #1: What are the camera's specifications??? Specifically:
- What is the resolution? (1080P HD? Less?)
- What is the field of view? (90? 120? more?)
- Does it have night mode/night vision?
Question #2: If I plug into the 12 pin port will the camera's video display on UConnect's AUX 1 (or AUX 2)? (A different thread implies it will, but looking for verification.)
Question #3: If the Mopar camera isn't worth the $650, has anyone found a suitable wired alternative which will still use the 12 pin port?
Thank you! DE
I don't have a Ram with those features, but they caught my interest a while back
do you have the
1) 9" Digital Rear View Mirror
Tow mode camera, Video mentions the normal Cargo camera in the 3rd Brake light, as well as the Digital Camera that is also in the 3rd Brake Light.
Then goes on to tell about the 2 camera connections in the rear bumper, although it does not talk about the 12 pin hookup
The same serial number for the digital camera that Ram uses in several places, like the digital camera in the 3rd brake light, as well as for your topper interior camera, the trailer interior camera & the trailer exterior cameras,
all have the same Serial #
You will find cameras with the same serial on several foreign & some domestic vehicles including the
Hyundai, if you go to the Hyundai parts website, you will see the same camera, same serial # for about 1/3rd cheaper than the Ram website price
Hope this helps some what
D
de1212
Alabama
GTyankee,
Thank you very much - yes, that did help.
Still unsure what the resolution of the camera is, as well as if the camera has a "night mode" (IR capability) or not.
When I go to the Hyndai parts sites, I couldn't find an equivalent camera to the one you have the parts #'s you provided.
DE
Towing Technology Group $1,095 Center High–Mounted Stop Lamp with Camera Surround–View Camera System Trailer Reverse Guidance
Tow–Mode Digital Rear–View Mirror Package $845 Digital Rearview Mirror Tow–Mode / Up–Fit Camera (Wired)
I believe these are codes AAN and AVF.
It seems like a group called Mopar Insiders is really knowledgeable on the Trailer Cameras
I took a quick look for the trailer camera serial number & i did not come across it
The serial number is also used on the HD Ram 3rd Brake light with Cargo cam & Digital Camera
OK !!
I found the video that mentions the digital camera & what i was writing about that they are cheaper at Hyundai
