Speed Bleeders
daveray9
Anyone know the size bleeders the Ram GEN4s take?
tantore
texas
do you mean power bleeders ? if so the units come with adapters to fit almost all caliper bleeder screws log in at (motive products .com) they make the power bleeders and give you all the info you need good luck
daveray9
daveray9
Quyonmob
Canada
I had a set in my old commuter Camry. Needed to purge the oem brake fluid, these were better and cheaper than a friend (friends drink all your beer and ask stupid questions while bleeding brakes).
if anyone finds the PN, I would run them again.
daveray9
daveray9
According to the website 2006 MY is that last year they made them for the 1500.
Its the concept I was trying to show. Many vendors make them now. Just curious if anyone knows the bleeder screw sizes.
daveray9
daveray9
Hemi395
Cape Cod MA
No problem[emoji106]
Suck out any old Fluid from the reservoir, fill the Motive up with at least a quart of some brake fluid, pump it up to 10 psi or so and go open the bleeders until they run clear. Easiest brake bleed/flush I’ve ever done...
daveray9
daveray9
Nice... swapping the front calipers this weekend. Will report back.
daveray9
daveray9
Save my life... put the front calipers in on the wrong sides. Took me 2 hours to realize and had kept trying to bleed them and the pedal just kept sinking. After throwning things for an hour and swearing about needing to get it towed I looked and realized the bleeders were on the bottom of the caliper. Swapped em then flushed the entire system with this in 20minutes. Thx for the tip!
Hemi395
Cape Cod MA
