Engine38FD
Truck is at the shop for a cluster issue, (lights would stay on intermittently after it's been shut off and drains the battery). Shop told me a possible solution is the speed sensor, which right now is apparently sending a signal to the cluster telling it not to get into sleep mode and causing the battery drain. I see the sensor is on the passenger side tire, is it around the rotor? Hard to make out on the schematic on Mopar site? How big of a pain is it to replace? Knowing that the shop will probably charge way to much to replace I found the part at autozone and will do it myself if I'm capable.
