Spyder Lights
PapawDan
Pittsburgh, PA
I recently got a set of Spyder Black Halo lights for my 2015 2500. Removed the OE lights installed the Spyder light on the drivers side… no low beam. So I go over the bulb (ok), harness connections for bent pins corrosion etc… all ok. Still not working. Took the Spyder light back out, and replaced the OE headlight… no low beam ?!? No 12 v power to low beam harness. Have high beams, running light and turn signal… just no low beam ? Can’t figure this one out… Any one run into this before ? advice ? Thanks in advance !
