Squeaks, Clunks, and Popping noises
konfidential
Baytown
the ihc 3/5 kit is squeaky as heck!..clunks and pops pulling in and out of driveways…while turning it squeaks like a raggedy POS…I greased it and all that.. nothing helps…thinking about removing it and going with just stock control arms with spindles or bt springs
*sidenote*
Looks killer and the stance gets compliments everywhere I go…but the ride..is complete sh*t imo
K
konfidential
Baytown
All my bushings are new…I’ll be pissed if they’re already worn…It feels like something is binding almost…I know my sway bay has the shorter end links from an f-150..and my shocks are QA1s..I do not have the rubber isolator at the bottom on the springs either…could that be the issue?…the squeaks and pops are annoying and embarrassing lol
crazykid1994
Are you on Facebook? Look up “high performance rams” and “tuned rams” if you are. They may be of better help.
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
If you don't have the rubber isolater on the bottom of the spring it will make a ton of noise.
Squeak, pop. Crackle and groan.
Do this as a test. Drive it in dry weather. Listen for noise. Then, wet the lower control arms inside where the springs sit with a garden hose. If your noise goes away, you have found the issue.
My .02
abouttobeglue
I've got the belltech 2/4, my rear spring isolators were shot and made it sound ragged as hell, replaced emz good to go. Started getting another creak, ending up being the sway bar bushings
K
konfidential
Baytown
I took my front sway bar end links off… still a clunk noise when braking and turning at low speeds. I see a tsb has been posted on ihc website about this issue..I checked for any movement and/or play from the control arms and everything is tight. I really hate to take everything apart to just get to the front springs
