kevkev
2004 5.7. 210K miles. I have changed crank and cam position sensor. I have cleaned the throttle body.I changed the map sensor. I changed the egr valve with a Mopar one.I changed the pcv valve with a mopar one. I just pulled the intake and replaced the gaskets.Yes, it needed it.Truck running great. I get behind someone who sits at a redlight and obviously doesnt know the law is right on red and refuses to move. Finally, they take off and I give it gas. Im dead in the water. I didnt even notice. Engine started right back up.No codes are ever thrown. I have also had my tipm rebuilt and a rebuilt FCM from mopar.I had my trans fluid changed and it is at the top of the hot mark when its been run. Im starting to get a little fustrated. Ive searched everywhere and it seems to be a common problem. Any ideas guys?The stalling is very random.Edit- New plugs also.This happens whether the tank is full or not. I learned a while ago, never top off and dont fuel with the truck running. I also have a new mopar gas cap.Battery is less than a year old.
