Starting to put a parts list together
HemiSport07
Central FL
In the near future i am wanting to start building a high hp hemi but im not real sure on what parts to use or if i want to go supercharged or turbo charged or n/a. so i was wanting some opinions on what direction I should go and what parts should I start ordering?
night hawk
Rockport, Texas/ Wylie, Texas
get a nitrous kit. 150 hp when you need it and itll only make your engine work hard when you use it, whereas an SC or turbo will constantly work your engine. and nitrous isnt that expensive. thats what im gonna do after i get a cam in about a month.
HemiSport07
HemiSport07
Central FL
Well I was thinking about doing a 392 stroker or bigger
HemiSport07
HemiSport07
Central FL
Yea like that but is one of those packages the way to go or is it better to peice it together
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Depends if your wanting to build it yourself or have it just drop in. If you decide to go with forced induction plan on going fordged and upgrading your whole fuel system and trans along with the motor build. The stock rotating asm will hold small amounts of boost for awhile, then your back to square 1. Best case is it just takes out a ring land and dosent hurt the block, worst case rods exit stage left.
HemiSport07
HemiSport07
Central FL
Yea I plan on building it myself I was thinking 392 or 426 I was just curious on what's the best pistons cam heads that can pull the most h/p and be reliable
garner
Harker Heights, TX
You'll also need a fully built transmission like stated above. It's a lot of work to make these trucks run sub 12s unless you're a 4th gen then it's kind of easy
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
If you are on a budget, then nitrous is the way to go. With a 125-150 shot and full botons, there is no reason why you cant go high 11's-low 12's with good air and some track prep. The top hemi truck engine builders are Sharadon Performance and Inertia Performance. Sharadon has a few supercharged stroker trucks going mid 10's to low 11's, and Inertia has built some awesome N/A setups including a few that are running alot of nitrous through them.
If you decide to go with a stroker, I would call both of those shops and see what they can put together for you.
HemiSport07
HemiSport07
Central FL
Yea I was looking at the sharadon transmissions stage three I'm not really on a budget cause I'm building a seperate motor I just want to keep it reliable cause it is my DD I heard from some people that if I ever planned on forced induction to build a 426 cause the 392 doesn't like boost any opinion and what do y'all think about the sharadon transmissions?
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
Depends on what block you start with. If you are keeping the 5.7 block and planning on boost, then I would go 370"...392" if you want to stay N/A. If you are planning on a 6.1 block with boost, then a 392" would be a better option...426" if staying N/A.
As for the transmissions, Sharadon makes the best transmission available for our trucks. They have put thousands of hours into developing these transmissions and they are behind the fastest hemi trucks including 2 Rumble Bees running mid 10's and low 11s.
HemiSport07
HemiSport07
Central FL
If I used the 5.7 block went to a 392 could I spray with forged internals?
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
The cylinder walls are going to be pretty thin with a 5.7 based 392", so you would be cutting it close. A well built 370" will take a BIG shot of nitrous without any trouble. Sure, the 392" is going to make more power N/A, but the difference in power is a simple nitrous jet away with the 370". I would rather play it safe and know that I can run a bigger shot of nitrous if I needed it. It will be better for you as a DD as well.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
The 6.1 blocks are getting harder to come by now that they are no longer in production. Matt on the 5.7 345 ci build to a 6.1 370ci build the walls are still semi thin unless your gonna get your displacement from the stoke. We did a 5.7 knocked out to accecpt a full 6.1 rotating asm and I thought the walls were thin to not be sleeved. That being said that motor went through hell with no issues.
casey1981
