Steering Shaft U-joint
smoothee
St. John's, NL
Has anyone replaced this? Mine is rusted pretty bad and in need of replacing, but I can't track down much info on the process. More so curious if anything needs to be done inside the cab to allow for slack?
PaulTGarrett
Grumpy old man
Tampa Bay, Florida
408 Cummins Turbo Diesel
I haven't replaced the joint on either of my RAM pickup steering shafts but did on my old Jeep pickup. It was pretty straight forward, just unbolt the old joint, drop the steering gearbox, then beat the hell outta it with a hammer and punch until the joint comes off the shaft. Install the new joint, tighten everything up, and make sure your steering wheel isn't inverted. If it is (like mine was), take the joint back apart and turn the steering wheel 180'. LOL
OK, that was the funny process... Seriously, it isn't all that difficult...
1 - put a locating punch mark on the steering shaft and gearbox shaft
2 - drop the steering gearbox off the frame
3 - remove bolts and knock the old joint off the steering and gearbox shafts (plan on a good hammer and punch)
4 - thoroughly clean your steering and gearbox shafts with degreaser and a ScotchBrite pad, take a file to any really ugly gouges on the steering shaft and just lightly clean them up
5 - do not turn or freespin your steering wheel, I have heard it can screw up the turn signal mechanism
6 - install the new joint, install the hardware with Loctite
7 - bolt the steering box back on the frame
8 - check all your hardware again for torque
9 - go have a beer
S
smoothee
St. John's, NL
Perfect thanks for the tips, appreciate it. Should be tackling it on the weekend. Your step 9 will probably be my step 1, 4, and 7 as well :D
PaulTGarrett
Grumpy old man
Tampa Bay, Florida
Oh!... When I say drop the steering gearbox off the frame, I didn't mean to take the arm or steering linkage off... Just drop it from the frame intact. All you need is some clearance to get the steering shaft linkage off of the gearbox and shaft. You -could- unbolt the steering column and get clearance that way, wayyyyy more trouble.
Another thought just occurred to me, I haven't looked at my RAM but some shafts have slip joints. Check yours first. You may just be able to unbolt the linkage Ujoint and slide the shaft up for clearance. My Jeep had a fixed shaft and a "rag joint" to allow for clearancing any body-to-frame flexing.
Rp3412
