Steering wheel shake at max turn
Warl
Corpus Christi, TX
Truck is the 2014 ram 1500 with ~7000 miles on it.
Hello, recently I've encountered a situation that I'm not sure is a problem or "just happens".
Recently I've noticed that when I turn all the way to the right at slow speeds the steering wheel will jerk back and forth. The only thing I think might've caused it is when I leveled the rear by lowering by 2". Do I really need to get it aligned after a level like that?
Etroze86
Grand Forks ND
Whats it look like back there? I dropped mine with 2" drop springs and didn't have an issue
W
Warl
Corpus Christi, TX
It didn't look that bad when I first installed but I'm assuming it settled that way but the picture does make it look a lot worse than it actually is.
Etroze86
Grand Forks ND
I would start up front, turn your steering wheel from lock to lock and when hitting the lock see if there is any potential binding or rubbing up front.
W
Warl
Corpus Christi, TX
Yeah nothing sounds/looks wrong. Maybe it's telling me "no more turning!" I have no problems with my steering other than that.
2249
Mine was going that but it was bad ball joints ... Yours its much newer so you shouldn't have that problem
NWRam1500
Mine did this twice yesterday. 2014 4x4 w/air ride at normal height. I tried to replicate it, but it didn't do it when I wanted it to. Like the OP said, full lock (left for me), steering wheel bumps back and forth. I have an appointment Monday for a list of fixes and my first oil change. I'll add it to the list.
W
Warl
Corpus Christi, TX
Make sure to post your findings please. I might go in sooner than you if not.
NWRam1500
Will do. i tried to get it to shake again this morning...but nothing. With the list I'm giving the dealership, they might have my truck a while.
Steve58
