Stock Infinity system problems
Bluesmoke91
2nd GEN Site Mod
Baldwin Park, California
When I try to play a CD it just says "no audio files found." they're all original CDs. I would understand if they were burned. any thoughts?
Sent from my DROID RAZR using Tapatalk 2
Meathook
Eastern Kentucky
4.7 Flex Fuel
If you put in a "stock" CD and it is not reading it then there is a problem with the laser eye in the player. You can buy a CD player cleaner usually at an office supply store or maybe Wal-Mart. If running a cleaning disk doesn't work then the Player is probably toast. If you do end up changing it out for a regular cd player it takes a special harness to bypass the factory amp.
Bluesmoke91
Bluesmoke91
2nd GEN Site Mod
Thanks Meathook, i might go back to the dealer to get it checked out. I'll be throwing in a double din but not for a while
Jus10case
