Stubby antenna
blade
florida
i have stubby and works fine for local stuff. u can get the base from rock auto for 5 bucks. my stock antenna was ripped off by drive thru car wash. ripped it out bent opening n fender and cracked paint n a spot all the way to metal sub straight
stubby great idea if u use drive thru washes
Puba08
Long Island
I have the stubby. Reception is not great here in NY. I get like 2 or 3 stations clearly. But I really don’t listen to regular radio. Basically bought the smaller antenna for working in the garage and the car wash.
ThunderMug95
North Prince George, VA
Bought the Rydonair off of Amazon. Reception was no different from what I can tell. It currently resides under my rear seat. It just didnt look right to me. Anybody that wants it can have it. Why the hell didnt they just integrate it and get rid of it....
RAM DRVR
Mid left coast - Oregon
CTD
Reception is great, I haven't noticed any change.
To get the ball end off, use some pliers and kinda work it back and forth while using a twisting motion, it's a press fit. Then I just determined the length I wanted, placed it in a vise and cut it with a common hacksaw. Next I sanded it down with sandpaper. Next I used a file to remove any burrs where i cut it and kinda file it to a taper, during the filing I would test to see if the ball would go on the end. Keep filing until you can twist it on with force. Then I just spray painted it semi flat black. I like it because it looks unmodified and performs as oem
^ This!
McBroom
Denison Tx
Hemi 6.4L
Pm sent
I love my truck!
Blue Mule 18 Ram 2500 4x4 C/C Off Road.
Gordinho80
Monroe, NJ
2012 1500 Big Horn
I’ll take it!!
Kimber45cdp
Nocona, Texas
you can buy the base, they are cheap, part number
5064395AF
https://www.ebay.com/itm/5064395AF-...h=item3f73bf7767:g:PgkAAOSwXk9bmn~m:rk:2:pf:0
I took my stock antenna off, removed the ball on the end, cut it to my desired length, filed down the end, replaced ball on top and painted it black...freebie
If you want to buy one, shop around because some lose reception and some whistle
I seen your post and did this also. 2 minute mod. I havent painted it yet because of the cold weather but it still looks awesome. I made mine around 16" and didnt have to do any filing to get the ball back on. just lined it up and tapped it back on.
JB1
Houston, Texas
Hey that's great, nothing better than a free mod. It's so simple I hope others try it
Navy Six Zero
DFW
Nothing like a "visual" aid to dissuade people from bothering you on the road...1500 HDX 2.jpg
Oh, and reception isn't too bad either...
Fitz-0518
Veteran 66-68
Central California
2018 2500. 2018 1500
Have the 13" Xantenna in black from Amazon on both Rams. Works in Ca just as well as the factory fishing pole.
