Stuck on what kit to get!
Turbofoedoe
Atl Ga
Well, im looking into lowering my 06 Ram 1500. I have 28x10 wheels with 295-25-28 tires. I'm looking into a 2/4 from Belltech but I've heard so many bad things about the spindles making the front wheels stick out more then factory and the fact that the drop isn't as advertised. I would like a kit that didn't require a lot of welding and hacking up stuff. I do tow my race car with my truck so don't want something that has super soft springs where it bottoms out.
What are my opinions on a good riding-functional kit for my pick up?
Thanks again
T
Turbofoedoe
Atl Ga
Ok thanks! I will check into the Ground Force kit as well. I've already seen the McG kits.
HemiBabe
DFW
I have the McG 2/4.5 kit.
When I had 22's the spindles did cause the front tires to stick out further then factory once lowered & I hit my fenders in the front, but the tires were pretty wide
Now I have 20's, you can still tell that the spindles stick the tires out a little wider, but I think it's all in the tires you're running as well; I have no problems anymore
BoBoway4
