Stupid bolt
GhostRam94
Hunstville, Texas
2009 Laramie CC
Ok so I've got an issue,one of the bolts that bolts in my tow hook and brackets for the bull bar will not budge, it's getting to the point where I'm afraid ima strip it so do you guys have any suggestion, sprayed a ton of pb blaster, wd-40 and penetrating oil and nothing, then heated it up with the torch and nothing....help!!!!!
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
I was gonna suggest heating it up, but it seems you've already done that. You turning the right way? Lol.
GhostRam94
GhostRam94
Hunstville, Texas
2009 Laramie CC
Yep I got the other 5 off same way and this is just being a real pain in the ass, honna keep heating it up
reefguy89
laurel de
Try hitting it with a hammer to jar the threads a little. Also try turning it the other way just about a quarter turn then try and loosen. Sometimes tighten then loosening the bolt frees it up.
You can also use leverage. stick a pipe on the end of the wrench to make it longer. i had to do that to get the body bolts loose when it did my roll pan.
GhostRam94
GhostRam94
Hunstville, Texas
2009 Laramie CC
Yea ima try everything that you just said and I just got out the huge ass torque wrench and breaker bar so hopefully it will help
BlackedOutHemi
DFW, Texas
2012 & 2012
Breaker bars are great. Made putting a lift on so easy!
GhostRam94
GhostRam94
Hunstville, Texas
2009 Laramie CC
Yea I have one but my compressor is broken, it won't turn on no more so it's useless
GhostRam94
GhostRam94
Hunstville, Texas
2009 Laramie CC
Ok so having no luck and me not being patient I almost lit me truck on fire and have almost stripped to bolt-_-
BlackedOutHemi
DFW, Texas
2012 & 2012
Got any pictures of the bolt? Odd that its stuck like that. May have to end up cutting it off and getting a new one.
BlackedOutHemi
DFW, Texas
2012 & 2012
Oh dang. Yeah....if a torch, PB-Blaster, and a breaker bar aren't working I honestly have no suggestions besides welding a bar to it and using that.
GhostRam94
GhostRam94
Hunstville, Texas
2009 Laramie CC
Hmm haven't thought of that maybe roll with it until Thursday when I go get my stock exhaust out back on at my buddies house
cwakefld
Central IL
I would say to heat it up and use a breaker bar with a good cheater pipe. Sounds like you have done all that though. Use a 12 point socket if the bolt is starting to strip.
I took mine out with a ratchet, didnt need the breaker bar, wonder why they are so difficult
GhostRam94
GhostRam94
Hunstville, Texas
2009 Laramie CC
Used a 12 point as that will all that will work, with a breaker bar and cheater pipe and all it does now is jump off the thread... Heated it up several times doing this and nothing.... Like all the other ones were a joke coming off except this one.... Can't even get it to budge with a wrench
BlackedOutHemi
DFW, Texas
2012 & 2012
Is the bull bar at some sort of odd angle making the bolt really tight? Maybe be sure to pull the bull bar up into position and try to undo it then.
GhostRam94
GhostRam94
Hunstville, Texas
2009 Laramie CC
Bull bar is off right now... And ain't going back on... Like I can move the bracket with a hammer if I want to
TexasRammer
College Station, TX
shoudlnt you use a 6 point socket?? use that and a big ass breaker bar or something, if that doesnt work then you might have to do what Eddie said or cut it off
GhostRam94
GhostRam94
Hunstville, Texas
2009 Laramie CC
Well I have tried both bud.... It's not that fact that it won't budget anymore, now I cant get a socket to stay on, it's a 15mm socket, looked it up on last instruction sheet to double check and the damn thing is being stubborn, I though about taking off the bumper to get a wrench on it but I'd rather cut it off.... But if I cut it off where???? There is almost nothing of the bolt showing
BlackedOutHemi
DFW, Texas
2012 & 2012
Ive had a problem with a screw I couldnt get to before. Ended up drilling it out through the top of the bolt.
Saleen5150
