Stupid projector headlight upgrade
rpr
GA
2014 Ram Limited
When I finally aligned and tested my retrofit build, I used AlfaOBD app, changed the setting to High Intensity Discharge for the headlights, and also set the high beam to LED (I have a Profile Hi-Lens LED projector there) and haven't had any issues. Changing the setting to HID in AlfaOBD eliminates the pulse width modulation.
I have a DDM kit with their Ultra Canbus relay system on my 2014 with the stock projectors. It works, but the HIDs in the low beams have disappointing output. The LEDs in the high beams are great.
Are there any settings in the AlfaOBD app that would help me in terms of light output for my DDM HIDs? What exactly does the HID setting do, just turn off the PWM? I’m assuming this app would not offer any increased output from an aftermarket HID system that is working, but thought it was worth asking.
Cableman
Longisland
I just ordered the ultras, non canbus cause i have alphaobd. Hope im happy! I did the 35w, are yours brighter then the stock halogens? What color bulb you go with?
rpr
GA
2014 Ram Limited
I have the 35W in 6K color and they have a bluish tint and disappointing output. I assume it could be partly due to the factory projectors. I don’t think they are brighter than the factory halogens.
Cableman
Longisland
Damn that sucks
rpr
GA
2014 Ram Limited
I was told the glass in the factory projectors have a blue cast to them in my model year (2014). Cheap way for Ram to make it look like they have stock HIDs when they don’t. I’m not sure if that’s true or not, and I’m not sure if that would affect light output.
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
Should try uncle ben’s kit like the Honda crowd.
Cableman
Longisland
My 2016 i can see that color in the lens also. I wish i i waited on ordering them now!
JB1
Houston, Texas
I just installed DDM Ultra 35W 5500k yesterday, no blue light on my projectors
JB1
Houston, Texas
oh heck yes, my morning drive was excellent. Add some LED bulbs to the high beam and you can light the road up when needed
OnSale
5th Gen Crew
Philadelphia, Pa
*raises hand...
So, umm, only that monster $1600 Morimoto kit I keep seeing online is compatible with a Ram CANBUS? Or am I reading that totally wrong?
$1600 Morimoto relay Kit!?!?
I build ram lights all day long. Best bet is to buy a Bluetooth OBD Device (MX+ is best) and then purchase the AlphaOBD App. Total will be about $120. Cheaper then the Morimoto Relay and in the end, you won’t have tons of wiring and relays and crap that can fail over time.
Also with AlohaOBD you can change hundreds upon hundreds of other settings with these trucks and also if you want to upgrade anything on your truck to a higher trim version (like heated seats) you can use AlphaOBD to do that in a matter of seconds whereas a dealer would charge you $140-$170 just to activate the heated seats.
AlphaOBD pays for itself after one or 2 uses.
OnSale
5th Gen Crew
Philadelphia, Pa
Blue tint to the projector lenses will absolutely not affect the output as the NHK line of Projectors are all tinted blue and they are some of the best aftermarket Projectors on the market.
rpr
GA
2014 Ram Limited
I’m talking about my factory projectors having a blue tint. Are you saying NHK makes the factory projectors on these Rams?
Random_Walk
...what's this bolt do? *plink* ...oh.
Out
2017 QC 4WD SLT
Pentastar 3.6
Agreed, which is why I bought a OBDLink MX+ fob. ;)
OnSale
5th Gen Crew
Philadelphia, Pa
Yea I know you are talking about the factory oem Ram Projectors. What I am saying is that blue tint, added to any projector lens, will not decrease light output. I was referencing the NHK G line of aftermarket Projectors as an example of a very popular and highly rated projector that has very blue tint to the projector lens and it is not an issue.
2012 Ram RCSB 5.7: R/T Replica (in progress) | Mufflex DOD-M80 Y-Pipe Muffler Delete | K&N Intake | Pedal Commander | AlphaRex V1 Headlights | Innovited 35w 6000k HID Low Beam | Katana LED High Beam | MicTuning LED Fog Bulbs | Opt7 LED Tailgate Strip | All Black & Red Badges | Custom Hood & Bed Side Vinyl Graphics | Custom Fire HD 8” Tablet Radio | Alpha OBD w/ Mx+... [Coming Soon: AlphaRex Custom RGB Headlight Build | Katzkins Leather Reupholster + Custom Wrapped Door Panels & lots more]
OnSale
5th Gen Crew
Philadelphia, Pa
Let me clarify, when the projector lens is tinted blue by the manufacturer, it does not affect light output. If you decide to somehow tint a projector lens with some sort of blue tint or whatever, it will absolutely mess up light output and most likely the tint would catch on fire lol.
As for factory tinted lenses, no they are fine. There is even upgradable lenses for a lot of Projectors that are black, aka the “Black Series” of lens upgrades and they do not affect light output either.
OC455
Central NY
From what I gather it just stops PWM.
OC455
Central NY
I would look into 4500-5500k bulbs as they will be closer to a white color vs. the blue hue you see. Also check to see if you can get bulbs rated for 50w and replace them and try a 50w ballast.
I' m running Morimoto XB D2S bulbs that are 5800k with 50w ballasts. They are white in color to my eye with a blue color along the cut off.
Cableman
Longisland
By turning off the bwm with alphaobd for the lows, the highs wills still work with stock halogens?
Cableman
Longisland
Man these ddm hids shipped from china, ordered on 7th or 8th and still not here yet! Showing tomorrow delivery
alphaprojects
