Stupid question, I know...
sbarron
Wasilla, Alaska
Put a thin layer on the side that goes to the valve cover and none on the engine side and put the gasket on the valve cover. Let it set up a little before install. Makes it easier to install and remove as the gasket stays lined up and attached to the cover.
Edit: and DON'T over-tighten.
Edit: and don't ask me how I know this.
dapepper9
Iowa/Nebraska Border
5.9L V8
2nd gens just need a good rubber gasket. Don't need sealant with the good even 10bolt system they use. Old LA engines you definitely needed it.
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
When I did my valve service, I used felpro gaskets, I only put the thinnest layer on the valve cover side to hold them in place. Otherwise, you dont really need anything. Torque specs are a must, or you will crush the gasket and end up with leaks.
95 in-lbs is the target mark.
Also, the only stupid question is the one you don't ask, then screw up.
kdryan
kdryan
All done and nothing exploded so I didn't do too bad. No oil blowing anywhere at least and it sounds like it might even idle better. Like I always say; If no one comes back from the future to stop you, how bad of a mistake can it be?
On to the next problem...
Gr8bawana
6.7 CTD
It idles better because you replaced the valve cover gasket?
Ramuel_L_Jackson
5.9 Hemi
Personally, I dont use RTV on valve cover gaskets.
Also, I have seen instances where a tattered valve cover gasket caused a vacuum leak.
joshhhh
