Sub boxes for CC
Keithrh12
Indianapolis
What are some options for under the seat sub box. Fox Acoustics has been sold out for a while. Crutchfield only has preloaded MTX, and Q-Logic only sells for Quad cab.
Does anyone know of any other companies?
regal81455
Illinois
JL stealthbox. Try SonicElectronix - if you put it in your cart and leave it there for a day or two someone will contact you and you can get it for quite a discount.
Also, NetAudio if you want a empty enclosure.
cam101
NC
I currently have a q bomb box. I bought it from a local shop. I will be building a fiberglass enclosure soon.
Keithrh12
Keithrh12
Indianapolis
Let me know when you wanna get rid if it!
What size speaker
cam101
NC
What size speaker
I am using 10s. I had to modify the box to fit my new JL shallow mounts.
uncledon
Beamsville
I have a Bbox single 10 and it sounds great.. Needed to seal the terminals to get a proper sealed setup. Installed a JL10W3v32 its perfect in my opinion. If anything I need to upgrade the front sound stage to keep up so I can take advantage of its full potential. At the moment I have it backed off so it doesn't overpower the rest of the system.
BlownGP
Houston/Baton Rouge
Do they make q bomb boxes anymore. Those seem to be on pair fox but I can't find them anymore.
I want a singe 10 ported on the drivers side.. Can't find anything
RobertMcColl
Tampa
Check out Net Audio. I have one of their underseat ported boxes. The thing is awesome. Expensive and a long wait but well worth it. They have quite a few options of different boxes for these trucks plus he will custom it a bit for you to suit your needs.
