Sub wiring problem help!
frontrowjoe20
Orange County, NY
2013 1500 Sport
So I ordered (2) CVR 10 4OHM subs to go with the kicker dx1000.1 amp. Instead i recieved (2) 2ohm subs with the dx1000.1 amp. Is this combo still able to run both my subs at their 400RMS needed? if so how should i wire them?
F
frontrowjoe20
Orange County, NY
2013 1500 Sport
But if i had 4ohm i could get it to 1ohm at 1000w now ill be at 2ohm. arent I losing 450 watts to the subs?
UNBROKEN
2012 Ram R/T
It says that amp does 1000 at 2 ohms.
You can always wire them for 1/2 ohm and see what happens. lol
It's only fused at 60 amps...I doubt you'll get 1000 out of it anyway.
F
frontrowjoe20
Orange County, NY
2013 1500 Sport
ohh okay....so if i wire 2 ohm which i can do, i should be good to go? last years model was 1000 at 1ohm. thanks for the help. being a newbie to this sucks lol
audio1der
Airdrie, Alberta
It all depends how new that amp is. If it is new and will do 1000 @ 2ohms (you still need 14.4V to "make rated power") you're fine.
If its the old one I'd raise hell and get the subs you asked for, OR get ANOTHER pair of subs haha
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
all DX do max at 2 ohm, wouldnt play at 1 ohm.
