Subwoofers?
isaacapo
Colorado
looking to add 2 Rockford Fosgate 12’s
In my 13 sport, I have everything but the wire connections which idk where to start.. any links to some adapters?
Elevated 2013
Huntley, IL
I’m guessing you don’t have the Alpine system in your truck? I don’t know what the connectors look like behind the radio and if they change between the 5” and the 8” radio. But That might be a question coming your way as to which size radio you have. I would think the speaker wiring loom would be the same regardless but I just wanted to give you a heads up on that question.
isaacapo
isaacapo
Colorado
sorry, forgot to mention that I don’t have the alpine system.. and my radio is the 8” radio
MD
Get the pac amp pro AP4-CH41 R.2 with t-harness. There are two versions for the ram. The first version only works with the alpine stereo the second version works with both. R.2 is the second version. This will give you a rca output for your amp or other accessory. No wire splicing necessary and you retain all of your factory functions.
MD
@ListenOverSpeakin thanks a lot man just the information I was seeking I appreciate it much
This forum is the gift that keeps on giving. I’m just doing my part. Also, subscribe to the 5star YouTube channel. They have some great videos about installs, products and industry tech.
rocket61
New York
Would this interfere with the Infotainment 4C retrofit interface? I upgraded my 2014 uconnect radio to a 2018 UAQ so I could get CarPlay and had to install that 4C interface to retain my heated/cooled seats and heated wheel. Don't think there would be an issue installing this pac amp pro unit, just hesitant since this would be the second thing between the radio and the amp.
For reference: https://www.infotainment.com/products/infotainment-4c-retrofit-interface
BoBoway4
