Suggestions please.
DRkNESS
South Jersey
Has anyone gone wider then what is highlighted on their factory wheels with
Bilsteins ? I'm looking for a slightly more aggressive look without having to swap out my current wheels.
DRkNESS
DRkNESS
South Jersey
This is what I'm currently working with.
DRkNESS
DRkNESS
South Jersey
My apologies, I'm referring to wider then my current 275/60 Michelins that I have on there. I want to stick with my current wheels, and place a wider tire on them. I'm also not adverse to adding a slightly wider fender flare.
AustinB
Banned
San Diego, Left Coast
Ah yep, every now and them you come across someone that claims they're running 35x12.50 with no spacers and zero rub. I'd have to see it in real life to believe it, or recommend it... but just passing what I've read on here and other places.
IMO
Taylo1
Childress, Texas
I'm running a 295/55/20 on stock wheels with no problems. I also had a 305/55/20 on stock wheels with no problems. 33/12.50/20 will work with no rubbing.
PassivAggressor
What type of tire do you want? I see you have SRT's so one would assume a street tire?
DRkNESS
DRkNESS
South Jersey
Yes please as I've done the knobby off road look and wasn't really feeling it. :(
13bighorn
Ontario Canada
I'm a pretty big fan of nitto 420's. They come in a 305/50r20 and I believe a 305/55r20 aswell so that would keep you at 33". I'm planning 305/50r20 on a 20x12 rim once I get some funds saved up
BlownGP
Houston/Baton Rouge
Only 305/50 in the Nitto 420s
You could go a little wider tires, but if you want a better stance. Just get a small 5mm spacer.
13bighorn
Ontario Canada
Yea I looked that up after I posted and noticed they only have 305/50. And spacers are soon to be illegal up here in the great white north. Only thing they will allow is adaptors
PassivAggressor
If you want the wide street look 305-50-20 is the way to go. I'd suggest maybe lowering the truck a tad though because they are a bit shorter than stock.
What my 305-50-20's looked like from the side on my truck.
