Suspension help
Dnicho
Oklahoma
So I got a 14 outdoorsman CC and I want to lift it fit 35’s but I don’t know anything about suspension and was wondering what I need to look for/ upgrade while I am already doing suspension work like ball joints, control arms etc etc
kurek
Northwest
If you want the easy one-stop solution just get Mopar P5155797 , install the front struts with the clip on the second from the top position, and get you some 35's.
Depending which wheels you have you may need either different wheels or spacers to clear your upper control arms.. may not need 'em.
Mopar P5155797 is the OEM 2" lift offering, it's simple and proven and affordable and if you don't do anything foolish you won't need any additional parts or need to worry about ball joints or any of that stuff. I've had it on my Ram since new - I did make a few changes over the years to fine tune it but never had an actual problem with the lift.
Anyway a bunch of arguing will probably ensue below but that's my input and endorsement.
Salty Ram
Hawaii
No arguments yet as I think the level will be fine it you're only looking to add the bigger tire. The caveat would be how wide you plan to go with your wheels (unless you're keeping the stock ones) and their respective offset. May have to do a little trimming if you go wide, but I do like the look of 35s on a leveled Ram. Personally though, I wanted the lift and chose the BDS Coil-Over kit and new BDS UCAs and haven't had an issue with my ball joints (as some members have).
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Simple way to fit 35’s and improve your ride
Jantelaw
