Suspension questions?
16Hemi
Northern Ohio
not sure if this would belong in lowered or lifted because my question is a little bit of both.
is there a suspension set up out there that would retain stock height but give me the ability to lower the truck under the conditions below
1. parked so i can get in an out better and load the bed better
2. drop the back to hook up the travel trailer or other trailers then lift it to stock height to tow
3. lower it some to achieve a more aerodynamic height for highway travel.
the last option i heard is a feature of the factory air ride systems and didnt know if there is a setup out there that would allow me to do the different things mentioned above?
Jrod
USAF 1997-2008
Virginia
2025 Laramie
SST SO
Just incase this pertains to you, some people living in states where the temp drops below freezing, for long periods of time, report problems keeping airbags inflated during the winter with factory air ride. I’d look up environmental restrictions, if available, with any aftermarket system you choose in case this would affect you.
16Hemi
16Hemi
Northern Ohio
Just incase this pertains to you, some people living in states where the temp drops below freezing, for long periods of time, report problems with keeping airbags inflated during the winter with factory air ride. I’d look up environmental restrictions, if available, with any aftermarket system you choose in case this would affect you.
I'm in northern ohio and we do see some low temps for almost half the year. thanks for the heads up on the limitations of the air bags
Reticle918
