sway bar end links.
stevens
2015 Dodge Ram sport 4x4 crew
i got 1 destroyed sway bar end link....im going to purchase 2 and just replace them both...but the truck has a 6" zone suspension kit leveled. its a 2015 ram sport 1500 4x4 crew 8 speed....i guess whats on there now is a mopar factory link with a zone spacer on top of it....but i just cant seem to find anything...and or i don't want to order a wrong one. thanks guys.
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
you might check Zone or BSD for longer links.
BOWERSFJ
Uniontown OH
Intetested in findings also ... I have Zone 4”, and it looks like just what you said ...
2014greatwhite
Western mass
I looked for ever to find them and couldn’t. I went through suspension maxx. I had to measure center to center on mounting bolts and they custom made me a set. A bit pricey I think $150 for the pair but only ones I could find
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
9C3742B5-80CE-481D-AC37-85AEEE7109D3.jpeg Zone and BDS both use swaybar endlink extensions so all you need are the standard end links for your truck. And you’ll reuse the extension. I went with moog ones they’re greasable.
shadowhawk
Southeast WI
@JB1 -- what are you using? I know you're lifted big
stevens
stevens
View attachment 145096 Zone and BDS both use swaybar endlink extensions so all you need are the standard end links for your truck. And you’ll reuse the extension. I went with moog ones they’re greasable.
yeah i have the extensions up top. so just remove the bottom portion? moog has a set they said.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Yes Sir, doesn’t have to be moog but they are good ones.
stevens
stevens
the only problem i have is the bottom nipple part with the nut above is stripped....i cant get the fkin thing off...or anything to hold onto that bottom nipple.
ram1500rsm
Trabuco Canyon, CA
Have you tried channel locks, vice grips ?, if that doesn't work, you can try to weld a nut, or take it any local mechanic shop and offer them $20 to get it off.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Mine was the same way I used a mini pipe wrench
Fatboy1989
