Sway bar link broke replace with?
RamHemi2500
North jersey
2015 ram 1500
I have a used 2003 dodge ram 2500 that I bought I've had it for a year and my sway bar links went on the drivers side. What is a good part to replace them with. I don't want factory parts. I should mention it has a 4inch suspension lift on it also
BAILEY1
St Tammany Parish, LA.
2017 RAM 2500
Dat Cummins!
I would suggest contacting the lift manufacture and see if you can get a replacement from them. What lift do you have?
RamHemi2500
RamHemi2500
North jersey
2015 ram 1500
That I am unsure of I believe it's rough country lift kit but it has reservoir shocks on it and when I contacted rough country they said they didn't make those shocks. So I am unsure what the previous seller did .
WhiteExpress
Midland, TX
If you google search it, there are a few manufactures who make a heavy duty end link.
It's a weak spot for sure.
You can also likely get a longer unit to compensate for your lift.
(if it's needed, some relocate the sway bar to maintain a factory like functionality)
