t-stat ?
ramhunter9
P-Star Jeep Wrangler
who is running a 180 stat ? any positives about running one .
johnnysart
Albuquerque
5.9 Magnum
I am it seems to trick the engine into thinking it's running cooler than it is. its a good cheap mod.
ramhunter9
ramhunter9
you gain anything from it johnny ?
HKkid
Missouri
I would really like to run this.
johnnysart
Albuquerque
5.9 Magnum
Not sure the only way I would know is if I was taking it to the track or towed something? which I don't at the moment.
I did notice on the gauge that it stayed cooler.
My truck does have good hp but at higher speeds--I need to get 4 56's and an electric fan.
Ramunit
I've been running a 180 stat for 4 years now. It is a great mod and the Hemi seems to like that temp, no heat soak and a bit peppier in the throttle.
RubberFrog
A 180 t stat really comes into play if you are running headers and a CAI. It helps with the kr caused by the lean condition. It does not cause you to run in open loop.
I'm not sure you'd see any benefit on a basically stock truck.
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
I like the 180 and think I run cooler. My Heat sucked last winter though but added e-fan this spring so think that will not be an issue in winter anymore.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
I have one in my truck and it seems to have alill more pep but I also had sean tune for that along with the other stuff.
nim81
Fredericktown, MO
5.7L
im running the 180 with ram air, modded iat and e-fan.. all seems to work great together... just need headers and my 4.56s......and a winch, and a body lift, and a new light bar, and 2 more 7" hid lights and this and that and .. well you get the picture
Eaton
X2, I have mine for the lean condition/KR (Intake, Headers, Tune). I haven't had any problems with the 180* t-stat.
BEAR
Redneck County, USA
2005 Ram 1500 HEMI 4x4
I'll agree with the others, I've been running one for a couple years now and the truck does run cooler, of course, and works well with the BM E-Fan and CAI.
Steve58
